Put my motor back in my gtr last weekend after a comlete rebuild. I have now done 500 k's and have come across a problem. There are drops of oil forming from the bottom of the bellhousing which im guess is most likely going to be the rear main leaking. Now heres the problem, when i sent the block and crank etc for machining they machined the surface where the rear main seals. He said that there should still be plenty of meat for the seal. When i re assembeled the motor i found that the seal felt very lose over the crank and i thought to my self this is gonna leak for sure, but anyway i took the risk and put it back in the car only to find that it is leaking :D Its not a huge leak but is only going to get worse once i wound the boost up and the crank case pressures increased.
So now i have been told that i will most likely need to fit a speedy sleeve to the crank. Has anyone ever come across this and had to fit one? Also do they make them to fit an rb26 crank and where can they be bought from? Im unsure how much has been machined off the crank either.
Any help would be good, Cheers
Edited by OFENSV
https://www.sau.com.au/forums/topic/168327-rb26-rear-main-oil-leak/
If he has ground it undersize, it will need a sleeve for sure to seal up.
Why the hell did he decide to machine that part for, if it wasn't hugely scored to begin with there is no need a new seal would have worked fine.
Its not gunna be cheap a sleeve that large in diameter.
Apparently from what i'm told, what they typically do now is metal spray the crank and then machine it back to factory measurements to save the sleeving process. To late now its all assembled though i guess...
Do a google search, most bearing shops carry the Speedi product range.
They are rather simple to install, choosing the correct size on is the hardest part, you have to measure exactly.
http://www.chicago-rawhide.com.au/Products/speedisleeve.htm
That might give an idea.
  • 16 years later...
Hey, not sure if you are still active on here, but I am chasing the same leak. Its a slow drip from the bell housing. Can't figure out where its coming from. Did it end up being the rear main seal?
  • 5 months later...
Well I am also keen to know what happened in the end from this thread or even just to hear what you ended up discovering @Kevboost7?? I also have just put the engine back in my R32 after a rebuild and I have a large amount of oil leaking from nowhere very obvious at all and am worried about my rear oil seal as well as can't find any other leaks so far.. Oil seems to keep dripping from the bottom of the bellhousing even after I have cleaned and wiped up all of the oil mess after the previous spirited drive and I haven't even driven it again since..! That makes me feel even more that it is still just slowly running down from the higher rear main seal because so much oil is coming out...
@Milhouse Sorry to hear that brother. I never got to the bottom of mine, although i didn't have a large amount of oil like you described. I just wipe it up as best as i can everytime i'm under the car and if i ever have to remove the engine, then i'd find the root cause of this leak.
It sucks that you just had your engine out though.
  • Like 1
Put some UV dye in the oil and see where it's coming from. It could be a lot of things like a valve cover leak at a hard to spot corner.
  • 4 weeks later...
Yeah thanks never thought of doing that before so might give it a go. Got the intake manifold off at the moment looking but nothing there yet either. Have a rear head oil drain which I thought maybe leaking for some reason but doesn’t look like… 😕
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
