I have the same problem. The guy who had the car before me put on a huge SARD dumpvalve and removed the re-circ system. Due to the dumpvalve being rusty etc the car now wants to stall when i come to a standstill and have to give it a small blip on the throttle to sort it.
No dumpvalve wont do your turbos any favours.
Gez
u made the same mistake i did, everytime i lift off the throttle the RPMs would drop so low that it would stall everytime i clutch in.
this is caused by a blocked BOV or no BOV at all. plump it back or let it vent properly and ur probz are solved
the car was tuned when i had a bov, i like the extra throttle repsonse i get from having no bov so i'm getting a tune soon and hopefully that will fix it, garret also proved that bov's do very little to prolong the life of a turbo.
Dont understand how you get extra throttle response.......Do you know what bov suppose to do.
Lol whatever, i have a BOV venting to atmo that is working 100% and i have the same problem. Though it happens very rarely. FWIW it never happened before i fitted the BOV.
Cars that use an AFM need a properly recirculating blow off valve to run properly, there are heaps of tricks to get around this, but they are all bandaids. There is no dowmside to doing it the way the factory does it, except you lose the "wank" factor.
Driving style is but one of the tricks that can counteract it :P
As above with the tricks :sleep:
Ways around it, but best to go with the OEM equipment (or GTR items if you need to)
I would say get the car tuned with no BOV or put one on there for now until you get it retuned, and to be frank you will find with a Plumb back you will find the turbo will spool quicker because it doesnt have to argue with air comming back at it, try it see how well you speak with air being rammed down your Throat. It works trust me :sleep:
Is say theres a lot of "thinking" in this thread. Ash, get the car tuned and ignore most of the advice here....
Ever seen the 180's that Nissan never fitted bov's to...or did they just make thousands of factory defects? :dry:
Ever seen the 180's that Nissan never fitted bov's to...or did they just make thousands of factory defects? :domokun:
it does need a tune, i've been meaning to get one for a while but i don't want to get one until i get my cams and valve springs installed.
Also to the guys who are bagging the idea of not having one on there just try it and then tell me if you don't notice the difference, also as i mentioned earlier they do not prolong turbo life as proved by garrett.
Quote Garrett
'The Blow-Off valve (BOV) is a pressure relief device on the intake tract to prevent the turbo’s compressor from going into surge. The BOV should be installed between the compressor discharge and the throttle body, preferably downstream of the charge air cooler (if equipped). When the throttle is closed rapidly, the airflow is quickly reduced, causing flow instability and pressure fluctuations. These rapidly cycling pressure fluctuations are the audible evidence of surge. Surge can eventually lead to thrust bearing failure due to the high loads associated with it.'
I've had this problem since I've had my car, I've just always blipped the throttle before it stalled.
For what it's worth, these are the things I have replaced for other reasons - Not to solve this issue, however mabye it will cancel some things out;
R32GTST, Stock internalsm stock BOV
Fuel Pump (Bosch 044)
AFM (standard R32 Green label)
RB25 Turbo
Splitfire Coil Packs
Cleaned Air Regulator
Spark Plugs
Fuel Filter
Maybe my BOV is blocked, I'll clean all that out tonight when I am chasing my boost leak
I do. :)
A bov is there for emissions and drivability. It hurts response as the turbo must refill the fmic and its pipework.
You obviously haven't tried no bov?
IF what garrett state *causes thrust bearing failure* a mate of mines VLT wouldn't have cracked 200,000km's on its STOCK JOURNAL bearing turbo while pushing 12-13psi for many years prior.
Have a read of - http://www.autospeed.com/cms/A_1457/article.html
Simon from Nizpro is well respected within the industry.
Ash,
Your going to have to do what Sinista has done, lengthen the afm to turbo pipe. OR step the size up to a 4" 90degreeish bend. Only way your going to get around it. :banana:
Shaun also recommends no bov; get him to tune it out, he may also recommend the inlet pipe mod.
Also..... Does your AFM still run its mesh? This helps prevent stalls also *in my experience*.
I do. :thumbsup:
Ash,
Your going to have to do what Sinista has done, lengthen the afm to turbo pipe. OR step the size up to a 4" 90degreeish bend. Only way your going to get around it. ;)
hopefully shaun can tune it out as i can't really lengthen my pipe if i wanna keep the standard airbox. The afm is missing mesh on one side (was like this when i bought it)
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
