Guys I'm gonna post up car #'s on Thursday/Friday. If you have pre-entered just quote your car number and we'll give you a sticker with the number on it.
Currently approx 7x cars pre-entered.
For those few people signing up to SAU NSW Membership, i'll get forms out to you guys so you can complete and we can get them to Shell to process.
  • Replies 484
Posted Images
7x meaning 70+ cars right... pretty good if so.
I can't make the entry as I have my gf's bro's bday nite out on saturday so its gona be a big one. will try to come see the show later in the day.
doesn't look good guys. the program got todays and yesterdays forcast down exact!!! i think today it was off by 1degree.
Tomorrow (this is dead centre of Granville) says 13^ and storms, followed by Friday 15^ raining. lets just hope that the weekend gets better.
ive got a program thats so freaking accurate with its weather forcast. it picked the storm we got here in Sydney, i didn't believe it when i saw the weather forcast for the weekend.
anyways i wont know the exact figure till Friday morning but atleast we'll know then and there. to give you an idea, here in Penrith tomorrow it'll be 15degrees, Sunny but not too many clouds and Wednesdays the rain will stop completely with hardly any clouds but it'll be a cold 12 degrees.
dunno about penrith... but this was spot f**king on for hornsby area :)
im gonna have to get a tent or some shit lol
Hate to be a stick in the mud !! - but if its raining on sunday i aint gonna be parking all day in what will clearly be a muddy paddock - i am hoping that the weather will be fine :) - hope to see you all there in glorious sunshine - cheers m :banana:
The council wont let us go on there if it's mud. We will be assessing the situation on friday. If need be we will postpone the event by 2 weeks.
i was afraid of that :D
gf wont be happy to find out i "accidently cancelled" our holiday :kiss:
As long as it's before 10pm. 10pm is cut off time.
Email with info and details about the day will be emailed to all entrants later tonite...
That's 10AM, not 10pm...
The online entry form is not working and i am going to have my computer taken away soon and will be of line for a couple of days(rebuild, new flux capacator, high flow, blah, blah) if it isnt back up soon i will bring the form on the day
PS it is pooring at nowra south coast.
Cheers Andrew.
Cheers Andrew.
I think it's up.?.. http://crankroom.org/sau/
Yea thats fine entering on the day is o k.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
