Nah turn 2-4 are the scariest. Thanks to all involved and flaggies out in the wet.
Jarrod... You're a stirrer. You just wanted to see carnage! Best spot on the track for it though.
Shame about your engine Nick. Hope it gets sorted soon and cheap.
  • Replies 57
Posted Images
cheers to all who helped out... it was a tough day to be a flaggy! it took me a while to work out it was Jarrod at turn 4... kept wondering why this clown was giving me the blue flag when I had half the track to myself! haha
was a new experience going round there in the wet tho and it helped me improve when it dried out, I was a lot smoother...
so yeah I still haven't called my mechanic to find out his diagnosis, I'm too scared... but its probably safe to say I won't be on the track again this year:(
huge thanks to Chris for driving me home so far out of the way, and everyone who helped push the whale out of the pits! hehe
Yeah it was a bit cold ouy there Nick..
It was a sad moment to see your R33 leaving Sandown on the back of a Tow truck.
Hope its not to bad and your back on the road soon.. :)
no drama nick. bad luck mate...u were ripping them up until it died..
Kev, Debra, Phil & Brett,
Nice to see all of your familiar faces again. It was an awesome experience. I think I might have been bitten by the circuit bug thanks to my (I know you like this word Kev) "Virgin" run. :laughing-smiley-014:
A thousand thanks to all the instructors, flag marshalls (Brett and Phil how did you like the massive slide on turn one?), caterer (I really didn't think the food was gonna be so lavish! I was expecting mystery bags and bread!), fellow drivers and the strange and friendly parrot.
See you guys next round.
Track slippery? :kiss:
Cheers,
Lydz
OH NO Nick, sounds like you followed in my footsteps :kiss: What happened?
Hope it's nothing too serious and it doesn't cost you big $$$$'s to get it back on the road.
accelerating out from the 3rd last corner in 3rd gear, heard a clank, clank clank, pulled off into pits, called tow truck...
I reckon its a big end bearing (again aghh) but it could be a valve or something else, its up on the hoist today top see whether the noise is coming from the bottom end or head
I ignored the whole oil surge/bearing issue that plagues the GTR guys... but definately going to get the oil feed restrictors in there this time etc... goes to show you can still have problems running stock turbs and street tires
meh... rebuild thread coming soon;)
Track slippery? :thumbsup:
Cheers,
Lydz
lol u cracked me up. every time I looked in my rear view ur car was sideways..
Cheers,
Lydz
WOW.. 4 years since your last post..
Anyway i was on turn 1 when you had your first HEKTIC moment (flag n)
you were good to watch..
But you got the feel of it .. :)
But you got the feel of it .. :thumbsup:
Hehe... yeah.. it has been 4 years since i've had my R33 you know!
I'm an old-new member, i'm mostly in Nissan Silvia forum now anyways. Back then I was the rare girl driving an import so it was rather intimidating to socialise with the community.
Thanks, I guess a have an advantage in the wet as i'm not afriad to slide. I always try to be as interesting as possible (show pony!) :)
How close was I to hitting the wall on the last corner coming to the back straight?! I almost sh*t myself... almost. :D
Till next time fellas!
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
