As discussed in a prev thread I said I would get a test website made up by my mate who is a pro web designer.
Ok here is a quick example my mate made in a hr or so last night as a test
No flash is implemented yet as this is just a test layout.
What does everyone think?
Love the banner , hehe shits over SDU :).
http://www.lunarpages.com/nbsp/skylines_v1.jpg
https://www.sau.com.au/forums/topic/169-new-test-website-as-discussed-before/
Drift, I like the idea of the morphing for the logo from 32 to 34. Sounds cool. What would that do to load times? I can't really imagine it slowing it down too much.
[/quote:6cada493ab]
Hopefully load times should be ok , hard for us to tell as both on adsl , but I will try in on 56k and see how we go, how isnt to slow as will look wicked...... mind u if u have cache set then its only going to be slow the first time u load the page.
i haven't deleted anything from SDU... never have. none of them listen to me anyway.
its not just us who moderate that forum anyway, the admins have full control over the boards.
Christian
hahaha ONARUN got smashed!!..
as for this website talk .. this is way to premature i believe.. we still have soo many other things to organise.. web site isnt even a major priority yet..
the time will come when we need to create the website etc.. when it comes im sure we will post requests then..
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
