up for sale is my pride and joy that ive had for the last 2 years.
its an 89 r32, manual rb20det, which has been extensively modified for both performance and appearance.
the details of which include:
full gold pearl respray thats less than 6 month old
bn body kit
18" rims
r33 brakes all round
dba 4000 series cross drilled and slotted brakes barely even used
hicas steering has been removed and bypassed lines
uat seat covers in black and grey
roof lining and parcel shelf retrimmed in black
sunroof
stereo with replaced speakers
3pt immobiliser and alarm
cruise control
black and orange interior
engine mods include:
full replacement link ecu with laptop control and hardware
r33 turbo
blow off valve
blitz pod filter
gt spec fmic
twin 10" thermo fans
steel intake pipe
adjustable cam gears
255 l/h fuel pump
exedy button clutch
exedy chrome steel lightened flywheel
short shifter
batmbl split dump into 3" stainless exhaust with high flow cat
alloy radiator and and new hoses added
gtr injectors
just had 100k service with timing belt and bearings and pulleys, water pump and thermostat changed
always serviced at 5,000 ks
i have 2 little kids and am changing my life style to suit them, sadly its time for her to go!
price: $15.000 ono
can supply roadworthy certificate neg.
car is on mornington peninsula in victoria
phone brenden
03 59885475
0424 694 654
Edited by fredzz32
https://www.sau.com.au/forums/topic/169034-r32-gtst-vic-drop-to-14000/
This is going to be a little different from your average question to a seller...
How do you go with baby seats in and out of this car? Does it have the seat mounts etc installed still?
I need to try and justify this to my wife... :O
Also do you have any pics of the interior, boot and engine bay? If so can you please send em to [email protected]
at the moment i have 2 baby seats in the back. i have a 2 yr old and a 4 mth old. yes the restraints are still in place.
its fairly easy to take kids around in.
my gf has a wrx hatch and its no more difficult than that!
ill get you some pics when i get home from work this arvo.
no worries mate
cheers brenden
this cars gotta go guys so ill drop the price to $16,000.
i have my eye on a nice forester and need to sell quick!
drives beautifully doesn't miss a beat!
  • 1 month later...
just fitted alloy radiator and new hoses aswell. relisted after family deaths
have had no time to sell. quick sale needed reasonable offers will be highly considered.
HEAPS of money spent on extras.
hey mate, i was assured it was high flowed when i bought it but after seeing photos of others
i think its still standard. in standard trim 3 tuners have said it will make the magic 200 no worries
after my injectors go in and a quick tune of the link.
dynod today made 175rwkw on 13 psi. injectors are at 70% duty so there is a lot
more room to play with.
this car is my daily driver so i had the tune kept conservative.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
