wheel works should be called nobody works every time i send a email for price they never get back to me . i ordered a set of rims from them paid in full when i ordered them told 1 week for them to arrive 12 weeks later and had to argue like hell to get a refund was told we dont have a refund policy . i said i dont have a ripped off policy i want my dough or im throwing old rims thru ya windows . ended up getting thr rims thru tempe tryes in 3 days from interstate . lol and thats where nobody works said they was getting them from tempes said nobody works never even placed the order
bunch of crooks imho
https://www.sau.com.au/forums/topic/169069-tyres/#findComment-3128242
