Hey,
Was gettin my link ecu tuned today on an R33 gtst series 2 and the tuner had issues of ithe car missing on all sorts of boost levels...
Its got the right plugs in it, fuel pressure is there, just wondering if anyone else had issues or if know whats causing it.
thanks!
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/
the car has run 10 psi on stock computer and had no problems, this missing that the tuner had was sometimes at 4 psi sometimes at 10 (inconsistent), he thinks it may be the fact that R33's series 2 do not have an igniter on them compared to series 1.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125468
plugs chosen by the tuner gapped to 0.6mm
Thats the problem right there.
If you have to gap the plugs any further than .8mm, its a dead give away you have a problem with the ignition :)
And that usually means (in order of occurence, first being most common)
* One or more coil packs is stuffed
* Wrong plugs are being used
* AFM might need a clean
* Faulty connectors/loom somewhere causing a weak spark to be produced
* CAS not working correctly.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125480
Well if it doesnt use the AFM, just pretend that point isnt there and read to the next one.
Mute point.
Yes, the increase boost (as already stated) is causing the spark to blow out.
1psi can have that effect if your on the limit already. It could also be the coils have now deteriorated even more.
Surely your tuner knows all this? Or are they just guessing?
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125498
Mute point.
what 1 psi are you reffering to? this missing was inconsistent happened at 4 psi, 10 psi, sometimes the can ran smooth, the next run it would miss as soon as it hit boost.
Doubt the coil have deteriorated even more cause i ran 10psi for no more than 3 weeks with the stock ecu...
what do you think about the igniter difference between S1 and S2?
Edited by Mid_Nite_R33
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125507
Dude, ive given you the advice (as have others), if you wanna argue/doubt/whatever. So be it.
Go pay someone lots of money and dont bother with forum advice
not trying to argue anything dude, just trying to work out what the problem is given what people say on here and with what i know about my car.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125531
He is right but there is some stuff missing from the story which is worth knowing. Link ECUs only have 4 coil drivers, so the way that it deals with your 6 coils (I had this issue too) is it fires 2 at a time - much like you do with wasted spark. One will be the one which is actually due for an ignition stroke, the other will be going into exhaust stroke. If your coils are getting "tired" then even if it was all working fine before putting the Link in, when they have to go double time due to the Links way of getting around of too few coil drivers they will show their weakness.
Only way around it is new coil packs or the more logical way which would be to convert to wasted spark, seeing as thats how the ECU is treating them anyway.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3129021
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
