Not worth it mate, Do a search as there have been a couple of threads on this. Basically to sum it up a turbo motor has less compression to allow for boost. If you took the turbo off and blocked everything up you would be left with a motor that had less grunt then a factory delivered NA.
Not saying it cant be done but the work envolved you would have to think twice. This price must be damn good as GT's can be picked up for around 20g's these days depending on where you are and four door models are cheaper again.
Or am I guessing because your on your P's you want to take all the gear off and re attach everything when you go of your P's?
Edited by smurf80
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3126235
Yeh, like he said you won't make much power because of the low comp ratio. Also the car will still say it's a R34 GTT on the chassis or vin and the rego so cops can probably still dog you (especially if they don't know what a turbo is and where to look fo rit)
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3126742
the car would still be on the rta computers as a gtt with a turbo. So the cops could and most likely would dick you.
If you did change it you would need to have that engineered to say it was ok.
However doubt it would pass, as they could simply say " what stops you bolting it back on after you get the ok to drive it"
Just stick with a NA from factory
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3127240
yea..it scoz im on restrictions i wanna put it back on once i'm off my p's.. i dont really care performance wise i know it woudl be worse, im just wanna know if theres any chance of damage to the engine? btw the car is 20k, grade 5, its really really nice. Is it worth it or shoudl i just wait a year?
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3128404
They did make Rb26DE's and the put them in sedans im pretty sure. Do asearch on them here as im pretty sure phunky monkey was the one that had all the info on them. I think they were marketed as a good tow vehicle or something from memory??
Edited by smurf80
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3131292
Is the car already landed here and 20g is the final price or are you looking on an auction website or something?
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3131295
If it's only a year till you can have a turbo one, i'd just buy a cheap economical car for a year, and use the money saved on petrol, insurance and buggerizing around making it NA, to modify the turbo one when you are allowed to drive it. The price for the car will come down in 12 months as well. You would really just be throwing money down the drain if you paid for someone to convert it to NA and then paid them again 12 months later to turn it back to turbo. Thats got to be a couple of grand spent on a car that after the outlay of extra money is still a stock GTT.
https://www.sau.com.au/forums/topic/169124-turbo-to-na/#findComment-3131456
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
