Left and Right Front Guards, Radiator Support, Headlights, Foglights, Parkers, Underfender-skirts, Crossmember...
Don't need uprights, suspension engine etc, just need all parts to repair frontend damage.
Prefer S2, but if not available or the price is right, will take S1. Can organise freight from anywher ein Aus, but prefer Melbourne.
Please contact 0425855540 or email [email protected]
https://www.sau.com.au/forums/topic/169260-wtb-stagea-frontend/
No dice? Its all good, we might just bring in a half cut.
Would people be interested in rear half parts if we brought down a whole car (ie two halves)? Stagea spare part availability sucks donkey balls in australia... so we might bring some down :P
i would definitely be interested in purchasing several random bits and pieces from you if you were to bring in a half cut for sure. prefer series2 though?
cheers oxford
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
