head light height adjustment on a series 2? really ? if so thats one more gadget I can play with when the car finally gets here.
I'm guessing that yours is a late (post-August) 1998 model, so it's a series 2, right? In that case, the 3-stage switch is probably for your headlight height adjustment.
Not sure about the other things, maybe post some pictures and see what the consensus is?
yep 3 stagea switch is for the headlights up n down. next to mine i have a little flashing LED for my blackwidow immobilizer not sure what your switch is for, but just bout every series 2 ive seen has something different there so good luck....
They are xenon from standard but compliance workshops remove them during their process, and replace them with a dodgey gay wiring setup and lights that blow every 3 weeks, lucky i dont do much night time driving and my dads mate owns a workshop i just drop in a take some globes when i need them.
saw a set of the original xenon resistor units, wiring and globes start at a dollar on ebay and finish for over $850 so they ain't cheap.
Question for everyone else; are compliance shops allowed to take these in my opinion if youve bought the car you own everything in it and they can't take it. how do i go about footing them up the arse and taking them back? ill just have to go flog $850 worth of intercooler n bits from their workshop
yeh this was talked about recently, not sure what forum but the conclusion was everything that car came with is yours.....i believe your well within your rights to ask for them.......not sure if i'm correct tho
I was alerted by someone else on these forums stating they didnt get their xenon lights back, so I made sure I rang and asked about it. Before I even got 1/2 way thru the sentence he assured me they bag everything they change and ship it over with the car.
depending on how straightforward the swap over is I may or may not swap back to the xenon lights!
hmm that doesn't sound right either - yes they will replace them with a halogen setup (like most other cars on the road except maybe new bmw's and lexus's?).
But i've had my headlights in for 12 months and only replaced them voluntarily to do a road trip interstate cos I thought my "original" ones weren't that bright. Turns out there was probably nothing wrong with them so there you go.
Definitely shouldn't need to replace them every 3 weeks (not sure if you were exaggerating but even twice a year is way too often!!).
While we're talking headlights, I did notice when I replaced mine that my right side headlight doesn't sit in properly. Normally the clip will hold it tight so it cant move - well thats how my left side one is, but the right side one can wobble about a mm or half a mm up and down. Not enough to make a difference and it definitely wont fall out or anything but I guess it does mean its a bit of a dodgy setup...
I wonder if the compliance workshops all use a similar setup or not??
if the compliance shop does the usual butcher job on the zennons you will never get them to work again as they hack out the wiring .pm me for more info nudge nudge wink wink say no more
it was bit of an over exageration ive replaced them 3 times in 12 months but that is too much in my books, ive done a bit bettter job insulating the plugs and crap they put on and havent blown since. The wiring for headlights looks hella dodgey in my car.
So definitely no go with putting Xenons back on? I just don't see the logic behind taking them off for compliance... I thought Xenons ARE a good thing, especially if they are adjustable (glare).
dont know how the system works but does the headlight height adjustment work with non Xenon lights.
Tried adjusting mine with the the three way switch on the right of the steering column and it didnt do squat. Im gonna have to also check the wiring on the right headlight set up cause I noticed that it flicked off & on a few times. Bodgy brothers strikes again.
Dont want to hijack this forum but just wanted to say, sunday night had a early model Impreza wagon & late model Audi S4 try it on. Chewed up & spatt out. Ha...............no mods, just a sweet launch
holy shitttt that volvo gets into it...........f+*#ck
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
