funny enough id like to know where the ecu is on a r33 also
:laughing-smiley-014: they are in the left kick panel (kick panel is for front passengerfor there left foot)
so inside the car on the left hand side up front below glove box :)
https://www.sau.com.au/forums/topic/169363-where-the-ecu/#findComment-3130133
  • 3 weeks later...
Bottom left side, passenger side. (under the glove box).
Take the passenger side "SKYLINE" garnish off slightly to reveal the kick panel connector. Pull it off, just some plastic connector thingys.
No real tricks in taking it out.. Just becarefull with the wires ey as you can see below..
What it looks like after the kick panel is exposed.
Take off the bolts circled, refer to image below to see placement of where the bolts are.
What it looks like when taken out, in the bracket:
When the wiring thingy is taken off:
https://www.sau.com.au/forums/topic/169363-where-the-ecu/#findComment-3166666
well it is a plug and play thing. you will need a 10mm socket to screw the harness out.
but you need to be careful with mines or similar pre tuned ecus....should put it straight on a dyno to make sure all the afrs and timing is safe
https://www.sau.com.au/forums/topic/169363-where-the-ecu/#findComment-3166676
