I have a set of coilovers on my car and im thinking about ripping them out and selling them because they are too bumpy for my liking (everyday driving). I have no idea what the spring rates are (they came on the car when i bought it) so who could i see about this. Also does anyone have any idea how much s/hand coilovers go for ? All i know is that they are Kei Office. I can take some pics later on.
Another thing...when u throw it hard in second...the ass ends up in the lane next to me...VERY tail happy so im assuming they are awsome for drifting >_< ?
Any help ?
Thanks !
https://www.sau.com.au/forums/topic/169701-coilovers/
did u get the adjuster things to change the damper
maybe changing this might make them better
i know my coil overs are very good
Yeh damper can be changed, im just not sure if i want coilovers any more or not. I really like how it GLUES the car to the road in the corners while going for a drive in the hills, and really, they are awesome, nothing wrong with them...but i don't know...at this stage im thinking of building a more comfortable car rather then a race/track car.
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3137126
i think a mate has nismo coils in his R34 and there more what your looking for got no idea about them cause they were in the car when he got it
what are you doing up at 5:50am Steve? cant sleep? :)
I need coilovers in my car too, any recommendations?
Tein?
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3137324
Well I'm in the same boat as Kisin. My car came with Tein HR's which are too harsh for what I use the car for. As such I'm selling mine, and am looking at around $850 as I have a set of C spanners to go with them to adjust the height (spanners go for $50-70 normally).
So Kisin I would suggest starting at around $800 like I am and see if they sell. Most importers ask between 750-950 depending on condition I believe, so Im startin in the middle of that.
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3137375
chances are the spring rates are way high. As sk says your car is probably skipping over bumps instead of having the shocks absorb them. Thats why yer arse is trying to overtake u.
Fit up a set of Bilstein with matched springs, and u will find better performance with better ride. They are an excellent shock for performance and dont give the rim shattering hit over bumps.
Price of your Kei office ones, depends on a few things - condition, pics (cos we all like piccies) and how much they are worth to you. If u want to get rid of em, dont hold out for a gold bar :)
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3137420
Another thing...when u throw it hard in second...the ass ends up in the lane next to me...VERY tail happy so im assuming they are awsome for drifting :P ?
Any help ?
Thanks !
id swap my standered suspension for ur coilovers....
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3137952
hey adam he has a R34GTT i dont think hell want the 33gtst stock suspension.
adam, quick tip make sure whatever coilovers you buy are rebuildable, as second hand ones may be close to stuffed in alot of cases (not saying that KISIN has stuffed ones, they sound awesome.).
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3138136
lol i kno was only joking anyway noone would wanna swap stock for coilovers!
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3138170
Any word on the coilovers being for sale KISIN? Im in the market for some second hand ones for my 33 gtst.
Sorry Hotwire looking for someting slightly cheaper than yours.
Will the 34 gtt coilovers fit a 33 ?
Im still not a 100% sure i want to let go of them
Any good places in adelaide that i can go speak to about this (suspension) ?
https://www.sau.com.au/forums/topic/169701-coilovers/#findComment-3138402
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
