What's the deal with the V35's screen: Does it come standard with every model or only certain models? What features do the screen/CD player combo have i.e. can it play DVDs, xVid, divx, does it have any inputs for iPods or XBOX, does it have TV? Also, if it has TV, is there any conversion needed to make it work in Australia?
thanks in advance
https://www.sau.com.au/forums/topic/169734-skyline-v35-tv-screen/
Some do have the screen and some don't. It was an option from the factory to support the NAV and TV functions mainly although it does have some other cool things like compass and fuel economy. Personally, I like the look of the screen setup better. Without it, it looks bare, but its up to you to make the decision for yourself, keeping in mind that the TV and Navigation system will not work in Australia and there isn't any reliable information yet about converting them without going aftermarket and splicing into the factory wiring and changing fascias and such.
There is a DVD-ROM unit that comes with the screen but it only serves to read the Navigation DVD. No normal DVD's or CD's can be read in there. Therefore the car out of the factory does not have any functionailty to read MP3's, Divx, DVD's, etc and has no inputs to easily plug in Aux devices like XBOX. You'll need an aftermarket unit for that. It does come with a pretty good in-dash 6 cd stacker though. There are connectors you can buy from the US to allow RCA inputs for your ipod, but you can investigate those options further when you buy the car.
See this thread for other info as well: http://www.skylinesaustralia.com/forums/in...howtopic=157379
Edited by -= SKiZO =-
  • 5 weeks later...
Only the Premium GT models come with the screen and suede leather interior. definitely nicer to have, however it is usless because you cannot play dvd's or use the existing navigation unit. It can be replaced for a cost of around $2000 to have it to Australian standards, however this replacement unit comes with DVD player including divix, mpeg, mp4 fricken spiff-ex if you want! haha, j/k. but anyway... everything is possible, just need to put your mind to it. something I can't be bothered doing! :cheers:
As far as the car is considerned, one of the best cars i've ever driven, for a car that uses only 7.4l per 100km , it's a rocket! beats GTS turbo's , HSV's etc. for a non turbo, performs exceptionally well. Rated at 230kw apparently.
Ummm... 7.4L per 100KM? Where'd you get that from? The screen on mine says around 7KM per L which works out to be about 15L/100KM. My true L/100KM goes anywhere between 13.7 and 16. I've got a sedan though so not sure on the coupes.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
