and another one for people who like seeing expensive racing cars crash
the two at the start are worth a small $900,000
I'm currently doing some work for the driver of the TVR and he says it the Biggest accident he has ever had
now this is ROFL
he squeezed his sandwich
or
http://www.youtube.com/watch?v=ULTZoigusNE
see its funny cause its not a child that is going to be scared and have nightmares
or if you think your really good @ spot the difference games try this
Spot The Difference
Edited by Madaz
i dont understand, he eats the the sphincter of the universe flavoured ice cream bullshit at the end, and the cameraman cuts transmission and starts having his way with the presenter...?
lol, i thought it was funny cause it was stupid someone would go to that amount of trouble to post a video on the net.
check out this crazy tosser.
05 yfz450 quad with a 06 zx10r ninga engine.
geared to do 230 kph at 13,000 rpm in 6th gear.
standard atv has around 50 hp at the wheels and the new and improved version has around 180 hp.
Needs a brake upgrade..
but a good laugh...
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
