damo were u being serious with the probably repost? surely not i mean it was on the friggen news last year as the most watched vid on youtube for the year.
and it played on a comedy movie giving him shit cant remember which 1. seth green made a vid giving him shit about it.
dosnt do any gunning or anything, but as if you can drive a porsche 917 on the street wtf
for you kids that dont know what that car is its an old lemans monster that is faster than f1 cars on some tracks not bad for going to get the grocery's in.
possibly a kit car though or something
also funky classic this 1 giving it some shit
http://www.youtube.com/watch?v=c99sgwxl2XI
f40 style :laugh:
Edited by Inline 6
classic vid dude, i used to play the 1st 1 on commodore with the "u were flying back there" comment that would come up no matter how slow you went.
that a typo its an f40 i always had a soft spot for it but the whole hardly any interior no stereo no electric windows thing is kinda offputting along with the price tag :laugh:
f50s are convertable things :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
