^^ >_< shit imho
meh, your entitled to your opinion, but to me there probably a million times better than anything you listen too =\
was just sharing incase there was anyone else from SAU there, i know there are a few metal heads on here! lml
Ha lowest form of wit right there
You agree its my opinion and im entitled to it yet proceed to flame my music without even knowing what i listen too gg Luke
Some people like listening to people scream i dont, the drummer sounded very good just couldn't listen to the song for long as that grate's me
music is something people (me) are very pasionate about, so why wouldn't i defend my choice??
i could have said lots of nasty and things about what music i've seen you post if i wanted to be petty and arrogant, but i didn't and didn't as you say "flame your music", i didn't even call your music shit, i just said i liked that music more. i dont need to know what you like to say "that if you think that is shit, i like whatever you do more"... least thats how i look at it
i just felt that your original comment was uncalled for and inflamatory "if you cant say nothing nice, dont say anything at all??". I tryed my best to defend my position without enflaming the situation, clearly that didn't work
and yes, one of the best drummers i've ever heard! =)
edit: sorry, pm wasnt working for me for some reason =\
seems you can get in the guiness book of records for anything
If you have ever played that song on easy, youll know how hard it is. I reckon he has more talent/skill than plenty of other guiness record holders!
talent and skill have no right being in the same sentence as guitar hero
what he was playing (either pettrucci or malmstein) is almost >impossible< to play on a real guitar.... and anyone who can even do a poor cover generally gets credit, as those two guys are insane...
and luke, what about joey jordison from slipknot? one hell of a drummer right there
-D
for the basketballers
if you dont watch that much nba, gillbert arenas was recently charged for pulling out a gun on his teammate in an argument about gambling debts. he was still allowed to play untill the court case untill he got suspended when he kept making jokes pointing his hands as guns at team mates.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
