I have a walboro fuel pump and i tried to replace it with the stock one.
failed, because the car wont start after that.
is the reason i having a faulty pump?
or i have to modify the fittings?
and on top of all these problems, opinions on walboro fuel pumps are welcome.
and would like to also know WALBORO vs BOSCH.
Cheers. :thumbsup:
https://www.sau.com.au/forums/topic/169857-walboro-fuel-pump/
walbro are good if you get a genuine walbro, and its the 255lph high pressure version.
non genuine, 190l versions, non high pressure versions, all not suitable for performance.
its critical that you get the right one.
people bag them out, but i can guarantee they haven't been genuine or the correct walbro pump.
took me ages to find a genuine pump when i needed one, but its great :thumbsup:
Sure, a pump can be doa, but it's unliekly. The question you should be asking yourself is, how much knowledge do you have in relation to installing pumps, wiring correctly etc.
Is the pump getting power? can you hear it prime? did you put the fuel pump relay back in? tested the wiring for power etc?
It's really hard diagnosing a problem over the internet.
i tested the wiring for power. there's power running through the wires. the only problem is there is no sound coming out from the pump.
so i guess it is spoilt.
however, does anyone knows the model number for the BOSCH 040 IN-TANK FUEL PUMP?
please post if anyone knows.
I kinda need the number.
Cheers.
before you go buying another pump i would check to make sure that it is in right, sounds like you have the + and - round the wrong way. also check the ground to make sure it is all good
is there any way to check the pump without putting into the car?
as in, check whether it is working.
Thanks.
If you wanna know Bosch vs Walbro - do a search.
End of the day, IMO they are sh|t.
I tried and tested a brand new, legit one (3-4 years ago). It didnt come close to what was expected of it
What's your reasons for thinking the Bosch and Walbro are shit?
What are your recommendations for a better fuel pump? Nismo? Tomei?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
