Does anyone else here work in East Perth and where abouts do you park? Let's get a skyline parking zone happening :P
I work in Plain St and I park in the carpark next to that Queens Gate/Garden park.. $4.50 for the day if you get in before 7.30 but its a shit carpark. Been wanting to check out some of the other carparks around the area.
https://www.sau.com.au/forums/topic/169953-work-in-east-perth/
Your leaving us to go off over east soon arent ya Kelly? I know you work down the other end of Plain St from me I seen you once coming off G.Farmer... I'm all the way down the other end accross from the Hyatt on Adelaide Tce.
I work on the corner of Plain st and Adelaide tce... a cheaper parking spot other then the Wilson one 2 floors below me would be nice... $9.00 if you get in before 9.30 and out after 3.30...
i'll stick to public transport though, before i start driving too much and get waay too lazy :|
Ryan are you at DoIR?
I work just a bit further down the road across from the WACA on adelaide tce. I am lucky get a free carpark there when i need. I find its a bit easier to push bike ride into work from there. its about the same time home and to work. its actually quicker when the traffic is heavier too
For East Perth just park at East Perth Trainstation and train 1 stop, or if your keen park at Golf Box... some business closed there so you can get away with it in the right spots (free!).
Me? I got V.I.P. status lol, parking in 'James Bond' aka Myers underground thanks to my mate who runs a skate store in forrest chase (and thanks to security that turn a blind eye when I park in centre managment bays :unsure: )
thank f**k i live in east perth and have secure parking
but public transport sucks, waiting for the bus/train... and the $$ isnt exactly cheap
and at night you get all these drunks/weirdos drinking on the bus
id much rather drive
btw is the royal street and plain street carpark the one across from the WACA?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
