Try H20 insurance. Underwritten by the RAA.
Im 35 dont know rating though , plenty of fines ,Mods to car (32GTR) full comp , $880 per year.
Classic car was a painful experience , and charged $1180.
the only difference was an extra $500 in the excess
Hope this helps.
H2P - Hard to Place Insurance. Good agreed values.
H2P told me $1000 32yr old rating 1 - thats what sux with insurance agencies theres no hard fast rule get them on a god day and you get good price with all inclusions ring 5 mins later get a bad person and pay more and get less
H2P dont mind about mods either
i went with famous cause i wanted pay by the month and they were the cheapest with an agreed value of 21.7g if i didnt do pay by the month i would of paid $700 full comp but monthly payments are $77bux x 10 months
Only had my R33 since October but had H2P rite up till March then the were stuffing me around... the best advice i can say is find a insurance broker i did and went from $120pm to $80pm and hey better coverage in case of accidents. my two cents
^^ or do the brokering yourself
Steve, did you recieved quote from Famous through the phone? i tried sending them a online quote and never heard back from them.
yeah i rang them its a 1300 nimber so cost of a local call
Famous Insurance 1300 886 029
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
