Hi all,
I want to get an after market boost gauge for my car but i dont want to mount it anywhere on the dash nor the pillar.....
so i was wondering if it is possible to take out the factory boost gauge and put an after market one in there..??
anyone done this??
i'd love to see some pics.......
Cheers.
https://www.sau.com.au/forums/topic/170378-r34-factory-boost-gauage/
yeh u can defiantly do that, theres a DIY article in a recent auto salon mag.........or was it HPI.....i dunno.
basically u just rip out the old one and stick in the new one, and run leads through ur car.
ull properly notice that after market gauges are alot bigger aswell so u might have to carve ur existing gauge pillar a lil
Interesting...... thanks dude.
I'd still love to see some pics if anyone has done this....
also, how recently was it in a magazine??
If anyone knows which one, if its still out so i can buy it, or if anyone has it and can scan it and pop it on here somehow i'd really appreciate it....
cheers!! :O
here ya go buddy, hope this helps!!!!
It's in this month's Hot4s... we did it for the editor >_< Look for the mag with the Mirage on the front I think :laugh:
its issue 152, the cover is of the pink R34 with 20" cromies (its actually a 33 but u cant tell from the front cover)
nice work satanic good joB!
so is that hot 4s like u thought or something ells
Those Blitz gauges look so good..
Damn they look hot! Would they be 52mm or 60mm gauges? Hard to tell if they are flush or sitting out from the pics (a bit dark).
Getting a 34GT-T this week, thinking I might try this as one of my first projects over the next month :thumbsup:
I went with a stock like fitting.
52 mm guages bought from just jap.
The guys that installed them for me made a custom backing plate to fit the guages to the guage pod properly.
If I could do it again I wouldn't have chosen a smoked face guage as they are a little hard to see during the day, but at night they look so good :cool:
Thanks Yo-Yo, they look pretty good. I was keen on getting the 60mm saber gauges but just not sure how they would look fitted in there as compared to the 52mm ones. Anyone got pics of 60mm gauges fitted in the cluster?
EDIT: My bad saw some of the pics above of the DEFIs installed and im guessing they are 60mm ones. They look a bit funny sticking out of the cluster though...
Edited by Suj
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
