shifty price dude.. look elsewhere..
I paid $50 for a my volt's to be done..
Just research it dude, it's easy to install yourself..
Thanks,
I'd like to do it myself but I work 6 days a week and don't wanna do it on my dayoff
would like someone to do a proper job
Cheers
Ford
meh for that price I'd get them to do it.
You have to:
attach senders (2x oil, 1x water). boost is probably not electrical so you need to run boost line
run wires through to dash
find power and headlight power
mount/install into the dash somehow
make sure there are no leaks or interferance.
For those that have done it themselves....how long did it take? I took say 2 hours per guage and had lots of trouble placing the oil senders - which makes $90ea a bargain really.
the oil senders are pretty easy with a sandwich plate, water can be tapped off elsewhere
wires through dash is easy if you know where to shove em
always easy to find power mang
tape, mount, wedge to dash
checkaroonie
my first boost gauge was a pain but when i put oil temp and press it was easy as!
Ed - Im looking at getting an oil temp gauge so I'll keep you in mind!
Just dont know where to get it mounted - I like it out of sight.....maybe replace my ashtray?
Has anyone got a gauge where their ash tray used to be?
Cheers,
Chris
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
