Hey i've searched around and found Hicas removal for GTR etc, but nothing specific to cefiro, 32 etc.
I'm in the process of removing my hicas lines, as i've had a lock bar fitted and blocked up the lines, and since then i've done a rear cradle swap also. so basically i want all the lines gone completely.
Started by removing all the plenum etc, to make life a bit easier.
1 - Start off with a pic of the hicas unit in the engine bay.
2 - Next there are 4 lines going into this one area, what is this going into? is it the steering rack (i've read that the hicas has nothing to do with the steering rack in other threads).
Can i simply undo all 4 of these and put bolts in them to block them up?
3 - This is how my hicas has been blocked off for the past 2years. I'm wanting to remove all the lines completely.
4 - Following the blocked lines up toward the engine bay, i came across this joiner/block with the lines running into it. What does this do and once again is it simply a case of removing it.
5 - Up further from this joiner/block the 2 rear lines go into this spot where the 2 lines from the hicas unit go into also (same part as pic #2). once again - simply remove and block up with bolts?
6 - Back in the engine bay i've now got the hicas unit again. the front line in this pic runs down the front of the crossmember and into the rear of the power steering pump.
7 - At the rear of the power steering pump is the hicas line. Can i remove the line, remove the pump's wheel (HOW DO I DO THIS???), and block up with a bolt?
Thanks again for your help it is EXTREMELY APPRECIATED!!!
cheers
-Matt
https://www.sau.com.au/forums/topic/170584-hicas-removal-issues/
2- Four hicas lines on the steering rack, this is simply a connection point for the hicas lines, you don't even need to plug them up, just remove the lines connected.
4 - Trace the lines from where you have blocked them right up to where they connect to the steering rack, removing any connection block things along the way
5 - Same picture as 2? Just remove those 4 lines, I don't think you can remove the block. Also, that looks freaky with the guy in the background of the photo.
6 - Should only have 2 lines left at the hicas unit now, 1 is supply from the pump (high pressure hose) and one is return to the reservoir (rubber hose with clamps). Remove the hicas unit.
You have a couple options with the hoses.
You can disassemble the P/S pump and remove the internals to the hicas side and plug the outlet, you will also need to plug the hicas return on the reservoir
Or, what I did was get a power steering cooler off an R32 and using the old hoses from my hicas removal, piped it up between the spare outlet on the pump and the spare inlet on the reservoir.
Yeah, the simplest option in regard to piping is a non hicas pump and reservoir.
But you would have to go to the effort of replacing your pump and reservoir, and buying them (money).
As simon-ae86 said, the cooler offers more reliability, plus you don't have to pull your pump apart or replace anything.
I know nothing.
Have you got the spare pump huddy????
See you Monday.
Oh and congrats on 5 yrs mate.
Edited by 32 4whore
"Charlie! We're gonna go on an adventure, Charlie!"
I was mid way through my engine conversion when I did my hicas removal. But the power steering stopped working, turns out the pump was rooted, but I thought I had stuffed up the hicas removal somehow.
Just make sure you don't run the engine without power steering fluid in the reservoir.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
