So...are these people on the forums?
If so, please contact me via PM with your details.
I'll get back to you once i recieve them.
Looking to get an alarm fitted within the next week.
Cheers
I've already linked the details for them in earlier posts in the thread if you've read it fully.
Requests for alarm installers in Sydney is one of the MOST COMMON requests here. Nothing brought up in this thread hasn't been said several times before. Please do the other posters justice and check the stickies, search, etc.
Hey
i've read the links and etc.
but iw as wondering who they were on the forums.
ie. userid
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
