you can buy the cheap china ones for like $300 check out just-jap they sell them along with alot of other places.
i personally think the china ones like shit house.
if your going to do it might aswell do it correct and get some good quality custom made ones not some cheap mass produce crap (personal opinion)
55,000yen later.... (custom made ones from japan)
I think these are the silver backed ones you don't want but i'll post the link regardless... http://www.psiparts.com.au/front.asp?pid=8...oductID=NI33L62 <- $540 a pair! There's also R32 and R34 LED lights (aswell as other imports) for others interested in them.
Last night in Joondalup I saw led afterburner brake lights on a silver r33 and I really want them.
The car had personalised plates but don't remeber what it said.
Has anyone seen these for sale before and where to get them as they make the rear look really interestinging at night.
Thanks guys,
Greg.
Hey, yer seen it around too ay, they look awesome, when the lights are off they are completely clear correct??? thought they might have been custom made because i havent seen them before anywhere ay...
if anyone knows where to get them, please let us know. (ps: theyre different from the LED ones i'm pretty sure... :s)
regards, Jon
Yeah i just got some of the type of light that you are after. I think they look ok. Same ones from JustJap. They seem to fit nicely and still have a red lens so they kinda look stock and not too ricey. They are really bright which is what I love most about them.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
