  • Replies 104
what sort of kws you making? How long you had it on for?
ive had it for like 6-7 weeks. i had it at 210rwk on 12.8 psi. stock injectors stock fuel pump. pfc. cooler, exhaust 3in.
toned it down to 10 psi for now cause the stock pump was unstable. 182rwk for now on 10psi. need a new fuel pump then il turn it back up.
Edited by R33GOD
hmm but there rated at 260kws arent they?
yea...it definately could go to 260rwk depending on the boost . i was just shy of 13 psi. oh yea..stock air flow meter too.
i have the smallest hiflow on my car also.
Edited by R33GOD
My car has 18's and is not lowered and i never have problems with any roads or car parks :D standard mspec bar ftw
haha I have 18's too but with suspension and a 400R front (sitting just over 100mm) it limits where it can go :P
I was getting around 300km's a tank in Perth, but coming to Melbourne I barely break 200km's city driving.
do you kno what the biggest high flow is rated at?
With the supporting mods you already have, the high flow should break into your desired power figure given 18+ psi boost I would think
You may want to look at the injectors too so that they aren't running 100%. My 850cc use a max of around 65-70%
i think slide rates them at the same power level. if you want to retain basically no lag get the one i have. chris has the max oversize and finds it a tad laggy. he is still happy none the less.
hey so you thin 555c injectors would be to small?
cool thanks, i just dont wanna go small and get sick of the power and upgrade again.. lol
haha trust me, you will want to upgrade again at some point no matter how much power you have :P
555cc should be big enough for your current goal, but go bigger if you have plans to go for more power later on
whats the next step up from 555c injectors? isnt the bigger the injectors the more fuel you use?
i got 740cc injectors and a 044 pump which is rated at around 800hp. I get 450km's to a tank.
so ok if i get slides high flow, and deatchworks injectors ill get th 66somthing c ones and with my existing mods ( FMIC, POD, POWER FC & Controller, Bosch Fuel pump, 3inch stainless steel exhaust, boost controller) i shold make roughly how many kws? and still get good fuel economy
I know mine's not a gts-t, but ive got well over 300rwKw on my gtr, and 550 injectors are fine, well i have a full fuelling system set up. Fuel consumption, i once did purely city driving n no highway, only got 270kms out of like 62L thereabouts, but i run a very rich tune. Tell your tuner how u want the tune to be, response or max output or etc. Dyno figures are not everything.
u should see 240-260rwk and depending on your tune n boost. i think you should manage about 450- 500k's a tank thats if you cruise. if you have a heavy foot i think between 270-300k's. exceeding the 220rwk mark might require you to change your afm also. :(
Edited by R33GOD
In my experience best to get injectors that were made to flow 550 not rebuilt to flow 550.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
