Hig guys,
not long ago i posted a thread asking the price of r32s. Ive decided to spend that little bit extra and get an r33 gtst cause the dont seem to be that much more expensive.
I was thinking about $15000. Does this seem about right for a nice and clean r33 gtst with excellent paint, bodywork and mechanicals.
I live in sa
Thanks guys.
https://www.sau.com.au/forums/topic/170751-buying-r33/
I agree - I was buying a car for wife the other day and just for interest searched R33 skylines (i've owned mine for 5 years now) I could not believe there were R33s on carsales.com and the like for 8 grand!
Remember this tho - even if you get a R33 GTSt for around $10 grand - you will be spending another ten grand on wheels/tyres/more boost/body kit etc etc etc ..... the amount of aftermarket stuff you will buy will add up
https://www.sau.com.au/forums/topic/170751-buying-r33/#findComment-3151676
$15000 should get you something pretty decent down hear in S.A but you should try and budget in money for insurance cuz these cars get stolen a fair bit. I bought mine fairly standard neally 2 years ago and the amount of money you spend doin it up adds up quickly if i could go back id prolly buy one already done up.
https://www.sau.com.au/forums/topic/170751-buying-r33/#findComment-3151796
$15,000 will buy you one fairly decent with a few niggles. $17,000 should buy you one with no hassles. Look for if it has had the belts changed, regular services/oil changes, good gearbox, no rattles etc etc. Basically look at all the internals first and foremost. Your priority should be the overall condition of the car. Not exhaust, rims etc. If I could go back I would buy one that had already been owned and driven by someone who did all the regular maintenance. It's so much less of a hassle. When I bought mine (which I am the first owner in Aus) I had a full tune, timing belt changed, new Iridium spark plugs installed, compression test, all fluids replaced with high quality products, an alarm that complies with insurance (most alarms don't which void your warranty if broken into). I spent around $2,000 on all this including labour. Then I had insurance! But my R33 runs like a dream and I treat it well. I see a lot of shitty R33's going around that look neglected and don't sound so good. So it's best to search around until the right one comes up.
https://www.sau.com.au/forums/topic/170751-buying-r33/#findComment-3151965
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
