gday guys got a Rb30e long motor for sale, its out of a 1988 manual r31 so it has the oil bungs and all that jazz you need for a turbo conversion. it ran well before we pulled it out but itd have a fair few kays on it and it didnt have a particularily easy life so ill say it suits a rebuild. there wasnt a nasty as bottom end knock or heaps of smoke but it had the typical single cam lifter tap, but anyone from round here wont be worried bout that :cheers:
engine is now out of car
80 bucks as a long motor come get it!!!
Ashgrove Brisbane
0402 728 256 or PM
Edited by racsov500
https://www.sau.com.au/forums/topic/170757-rb30e-long-motor-80/
hey if you want to pull it apart and give me the block and sump with only the crank. i dont need rods or pistons. i will buy it. but is there a chance you could deliver it to the coast. i live near wet and wild. let me know. i will pay 175 if you can bring it to me. cheers.
gday guys got a Rb30e long motor for sale, its out of a 1988 manual r31 so it has the oil bungs and all that jazz you need for a turbo conversion. it ran well before we pulled it out but itd have a fair few kays on it and it didnt have a particularily easy life so ill say it suits a rebuild. there wasnt a nasty as bottom end knock or heaps of smoke but it had the typical single cam lifter tap, but anyone from round here wont be worried bout that :thumbsup:
80 bucks as a long motor come and get it!! (no inlet manifold)
Ashgrove Brisbane
0402 728 256 or PM
  • 5 months later...
