Hot off the Reuters/AAP news service:
Sydney, 30/05/2003
*** NEWSFLASH ***
The Ducati factory race team today said it had "no comment" to the rumour that a stunning new talent was uncovered at a recent track day.
When questioned as to whether talent of this calibre is often seen at these events the factory representative shrugged,
"I'm not really sure..."
The lack of direct denial has fuelled rumours of a shake up in both motoGP and WSBK.
The race team manager, when asked to comment on the riding style and lap times of the unknown rider replied,
"ummm...I guess you could say he was in a class of his own..."
The unknown rider is rumoured to also attend Drive days in a high performance turbo charged super car.
For the moment the identity of the mystery man will remain a mystery. Motorsport fans world wide can only wait and wonder when the next display of track prowess will be demonstrated.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
