Changed from the 25 route....
Am chasing an RB26 head.
would love to but a top end complete with everything ie loom and ECU , but may look at buying the parts separately. Only interested in stock items.
Edited by Young GT-R
https://www.sau.com.au/forums/topic/171046-wtb-gtr-head-or-complete-top-end/
yeah there was one on there for 600 almost complete engine, (complete head) I can get one locally I just found out will look into price.
Cant work out if I want an R32 rb25de head or a GTR head (more $$$ but maybe worth it?)
still looking, r32/r33 rb25 head.......... cheap.....
Hi I am in Adelaide and have a RB25 Det head you can have for $250.
Might not be what your after or too far away.
Complete head minus the covers.
I could even supply the inlet manifold with throttle body as well.
that is cheap, but no longer interested in a 25 head................looking at 26 head now, thanks anyway.
So, I am after a GTR top end or will buy separately........
should also mention......unless you have been on sau for a fair period of time with a decent trader rating, I want to have the head sent COD with a deposit to cover time and costs. Just for safety sake.
this is the kind of thing I am after:
head
engine covers
plenum
injectors
coil packs
loom
ecu
exhaust manifolds
turbo lines
cas
that's what I want, if I have to buy the lot separately so be it, but my preference is to buy the list above in one hit.
cheers
I have a fully reconditioned R32 GTR head, new exhaust guides, cam tunnels rebored, valves ground, seats cut, vacuum tested, new valve seals, cam - bucket clearences set, face surfaced and all chemically cleaned.
Head with complete valve train and std cams only. All work done by JHH performance in Bris
Email me if interested: [email protected]
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
