Hey Peoples
Just getting the Stereo on my car figured out,
I want to have a 10 or 12" subwoofer with an amp for the sub and another one for the speakers.
My dilemma is that I don't want to waste to much boost space and I hate those pre-made sub boxes things that you chuck in your boot and go.
So I need some idea and photo's of different types of boot installs on Skylines.
I have an R34 but I'm guessing most skylines have very simlar boots.
Cheers
Josh
https://www.sau.com.au/forums/topic/171685-boot-install/
Hey Peoples
Cheers
Josh
Check out this thread..
http://www.skylinesaustralia.com/forums/in...=159050&hl=
If you search you should find some other threads
You can find/get a lot of good info here.. ( formerly Car Audio Australia (CAA) )
http://www.mobileelectronics.com.au/forums/index.php
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165660
Hey mate.. 33 has a bigger boot but r34 is a pain in the ass .. majorly because it has the step up in the boot for the fuel tank ..
theres my crap amp rack .. working on sub enclosure .. might get a pro to do it .. just cause im starting to be lazy
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165830
whateve... it had better be done for SNS :O or at least entered... i dont want the pres hurting you :P
my car is stripped at the moment... the boot is to bare metal, seats are out, dash is... put back in so i can move it... but it was out...
there are wires EVERYWHERE cause im re-wiring everything, adding 2 new subs in custom boxes, new amp mounts... basically, i have saturday sunday and monday to do most of the work, then afternoons... and it gets detailed on friday... :D
ill be pissed if its not finished...
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165907
I hope its finished because I can see those mofos are going to give the thunder a run for its money ... the power that they'll need will even give lightning a go :O
chix will love ur back seat... vibrations :P
Oh and a blew another fuse the other day ... wtf?! common it was the speakers that did it this time tho.. i wonder if im going to go deaf..
Im not going to make it to sns im working :D
Edited by DECIM8
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165936
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
