guys
i think the rain has gotton into my coils or AFM, wouold this make it spirt really bad
it spirts and carries on as soon as i put my foot down even with no boost
Please let me know or do i have a bigger prob
and can this be fixed
https://www.sau.com.au/forums/topic/171953-the-rain-has-made-my-car-run-sht/
how did u guess
one of the reason i am selling it, if i had the engine cover it would be ok but i dont as i have the cover so i htink the water got through onto the engine and maybe ontgo theAFM
will it dry out or will i have to blow it out
have you got a standard airbox? if you do, open it up and take out the filter, you'll find a pool of water at the bottom. as you said, when you put your foot down it does strange thigns, when the engine starts to come on boost it sucks some of this water (from the pool at the bottom of the airbox) which hits the AFM, resulting in instant power cut, really jumpy, splattery etc
if its a pod then take off the pod and see if there is any water in the pipes/in the pod
:P hope that helps
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
