Hi guys was wondering if u can help me with this problem
i have a 5 puck ceramic excedy brass button clutch.. its only 8 months old.. and now its slipping any idea... my car is only making 176 rwkws and the clutch is rated at 300 RWKWs.. the clutch relaese point is now about 3 mm from the top so i barely have to push the clutch in to dis-engage the clutch from the flywheel.. and when u engage the clutch again.. its like its not fully engaged back onto the flywheel..
is there a manual way to reset the clutch relase point ect.. like someone once told me you can adjust the throw out point from the clutch pedal up top..
any ideas... i cant book the car back in for 4 weeks at the place i got it.. and im just getting the shits.. spent almost 1k on a clutch and its rooted already.. i hardly even slip the clutch just take off liek your supposed to with a brass button..
Any help would be muchly appreciated
you can adjust the clutch master feel at the top of the pedal there is a pin going thru the clutch pedal held in place with a split pin. remove the pin, and you can screw the saddle in tighter or looser depending on how u want the pedal...
be warned the pin is an absolute bastard to get back in :)
you dont need to remoove the pin to adjust it, just loosen the locking nut on the fork that goes over the pedal. p.s i wouldnt be playing with that stuff unless you know what your adjusting, it adjusts the freeplay. yours could be incorrect causing the pedal to be always engaugeing the clutch and therefore wore your clutch out prematurely.
hey
i have one of these exact same clutches and its less then 1500 kms old... took it out to mallala for drift prac and before i even got out to the track on my way to a mates workshop it just all of a sudden started to slip while IN gear... in 4th at 3000 rpm about 80kph i would give it some throttle and it would just start slipping!!
gave it a bleed, didnt do much at all.. went out to the track and needless to say it was pretty useless.. im pretty disappointed with the clutch, considering i only JUST bought it.
not even making much power either... about 170 rwkw
nar. brassies ware out pretty quick. especally iff slipped
yerp i had one in when i bought my car from the previous owner fitting it.
I had to remove the driveline to fit my 3lt and while the clutch was out i replaced it.
Simple fact is buttons suck for a daily driver, or carpark shopping. Anyone who uses em on the street will make em slip soon. This is like the 10th person ive heard recently complain.
I also noticed they burn out the std flywheel as well which is a bitch, but lucky i bought a os twin to replace it with (flywheel incl.) The pedal feel is back close to stock, it doesnt slip or shudder from carparks, and will handle anything i throw at it.
ive had 5-6 puck clutches for years and never really have had much drama;s with them til this last one... its just useless and it has had bugger all driving done on it. it started slipping from the word go really.
totally agree that brass clutches are not for the street. They not only wear out the disc but due the the metal in it, the flywheel and also the pressure plate.
If it started to slip so soon it could be a hydraulic problem pedal may be still engaging even though its all the way out.
On the track though they can hold a lot more than an organic disc
exedy copy clutch was what I heard it was Simon that true?
didnt even know you could get copy clutches
its not a copy, but rather an exedy disk and seco pressure plate....seco being owned by exedy, so technically its all the same.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
