I am looking at investing in a sump extension. From what I gather Micks Metal Craft ones hold the most oil in them and seem to be praised as the best on the market. But, they cost a fortune and the engine needs to be out to install them.
What about the Trust ones? Is it true that they poke out the bottom and reduce the clearance of the car?
I know mods need to be done to the sump to fit them but can it be done on a hoist or is it s motor out job?
Are there any inherit faults with the unit?
Any help will be welcome.
thank you all in advance.
Edited by khezz
https://www.sau.com.au/forums/topic/172042-trust-sump-extension/
We run the trust extended sumps and are happy with how they perform, haven't had any surge issues with it on.
It is pretty much an engine out job, you need to take the sump off, cut a hole in it and weld the extension on. Also comes with an extended pickup.
Hangs about 10cm lower than the standard sump but we have never hit it, even on tarmac rallies.
No real faults, they and the Micks ones are pretty much the same.
You still have a stock bottom end dude, and to this day, i still dont see the point when its only a band aid fix to a bigger problem with the RB's.
Also no point if your having the motor out, you might as well rebuild it if your doing that.
Just put 1 litre overfill into the sump before a track day or whatever, and you will be fine.
:P
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
