looks pretty cool, didn't realise it was that easy to change over, i thought i would have to change the whole thing.
one of the bulbs is blown and hard to see the buttons at night, so will definetely doing that
thanks for the guide and the result pics. :cheers:
I thought you told me you wouldnt sell the LEDS seprately? :D
Now I find out great one looks like ill have to buy a set now... I just cant be stuffed pulling apart my car haha
Lies!!!! I'd sell you an old napkin if I thought you really wanted it :) I thought you meant like the individual rectangle LEDs...I can't get them.
This was the final trial and error discovery with the R33 A/C's finally a bulb!
Old napkin hey ... Been looking for one of those
Alright .. Well im guna need the R34 Setup in red and then however many other bulbs it takes to also do the air con .. including the ready made aircon ones.. Hit me with a PM on cost .. im also prob guna get some ultra bright parkers to match (white, HID WHITE) my new stock R34 xenon system :D
  • 7 months later...
So how many parts do we have to buy? Just the LEDs, or everything that in the photo? Or has most of that come from the car anyway? I need to do this desperately (actually, i need to get my "off" and "auto" buttons to work, but I didnt even know they lit up!!). Any one else have this problem?
You jsut need two T5 LEDs, then trim them to fit in the grey plastic base that is already in the A/C
Dan
  • 1 month later...
what about the R32s can u please post a DIY on how to change the speedo lights coz i've seen those LED b4 but i dont wanna buy them because i dont know where they go, i saw the A/C lights but i wanna change the speedo lights thanx, can post some pix as well :)
Dan
Dan, I just ordered the T10s on ur ebay site for my 33 gtst dash. All thats listed is the dash kits. What have I got to do to get the a/c T5s as well? Ive been reading around and so far word is that urs seem to be the go. :)
Also, just a general one for any1 who can help, cant seem to find a decent thread on this... the clock light and the actual climate control lcd display, ive heard its made with layers n the colour is only given on the final (or final-ish) layer... is this correct, has anyone figured how 2 change this n if so is there a tutorial? wouldn mind a blue clock to match the rest
cheers
Edited by Blayz
Dan, I just ordered the T10s on ur ebay site for my 33 gtst dash. All thats listed is the dash kits. What have I got to do to get the a/c T5s as well? Ive been reading around and so far word is that urs seem to be the go. :D
cheers
A picture of a r32 dash at night with red clock not the best pic but it shows what it looks like with a red t5 led instead of the normal bulb
pic was taken on a dirty ol camera phone
Edited by Oo_oO
hmm, the 32 and 33 clocks are situated different, but I managed to refind that thread I stumbled across ages back
http://www.skylinesaustralia.com/forums/R3...mp;hl=ac+lights
cheers
  • 2 months later...
so where do we get these leds?
hmmm found a place on the net that supplies the T5 and T10 LED bulbs, as well as T5 and T10 sockets. Would it be better to buy the aftermarket T5 sockets for an R34?
http://www.ledshoponline.com/automotive_dashboard_bulb.htm
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
