Guest INASNT
Originally posted by acsplit
about  1.30 this morning pulled out onto chapel from jam factory behind a classy calibra with tin can muffler sound and plates AMBZ wonder who  this was  :rolleyes: hehehe
when i first heard her car it sounded like her it was doing 200mph but it was probably doing like 40mph!! hahahaha
that exhaust is way 2 big for that car ambz!
oh, u r a farkin lasher 2
backk urrpp GFORCE
i was right behind when u were doing laps comming out from coles car park!!
hehehe
ahah funny cause i recall u sitting 3847238743 meters behind me cause u had ur woman in ur car and were too scared to come closer
ahahahahahah
i even slowed down sooo much and still u remained so far behind.. or maybe its jus cause i is tooo fast for ur rice rice baby that u couldnt catch up! :bahaha:
Guest INASNT
Originally posted by MzDfectd
i didnt lashhhh
it was raining
pointless going heathcote in the rain..
also i hear u were sitting in ur car eating and u spilt food on u and ur woman cleaned it up with a tissue
AHAHAHAAH
wooopishhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
KODAK MOMENT
:shake:
well u heard wrong didnt u!
when i sat down on 1 of the chairs i didnt see the bird on the back of the seat and a bit got on my back, so i dont know about u but i cant see my back without a mirror so she cleaned it off! Now is that OK with u??
And as for your car, its sounds like a combination between a lawnmower and a weed wacker gone berserk, so i wanted to stay away or the other road users might affiliate some association between ur and my car! :rolleyes:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
