CP'S are good. they usually mesure up all the same. (no variation in size)
wiesco are also very good but usually reqire individual boring as they vary in size a little. ie 1-3thou diferance in diametre
both need balancing and both use good rings (file back) and wrist pins :) but both like all american pistons have a faily loose piston to bore clearance. so unless the ring gaps are perfect they will "breath" a little
i dont like cp rings, i would substitute them.... but like R31NISMOID said listen to your builder as there are some brands i just wont use and some require more work to get satisfactory results...
oh yeah do not use thier recommended piston to bore.... way to big.
breath a little, as in show leak on a leakdown test ?
Can get both for the same money, so it seems the cp ones are the best choice ?
and R31Nismoid, builder doesn't know which one is better :banana:
edit : hmmm,mr uras above seems to not like the cp ones ?
Edited by -wj-
I work for someone who happens to do alot work with CP PISTONS and abit of WISECO...
The way i look at it is.... If the V8 Supercars and numerous Top Door Slammers use CP Pistons and we havent seen a failure because of a cp piston or ring (aslong as there installed properly!!!!!!) then i think that speaks for itself.
Wiseco arent even in the same league..... there measurements for standard off the shelf pistons vary way too much and dont even get me started on there custom pistons!!!
The only problem with CP PISTONS is the timeframe for custom pistons..... 6 - 8 weeks (but we havent had any returns of custom pistons yet, they look and perform unreal!)
Cheers BOOSTA (Pete)
Thats a warning sign mate.
If a builder has to ask which are better suited then they havent built an RB before, and certainly havent used a range of pistons.
Is there anyone else you can use? Its a big expense to stuff up :)
the man has done alot of work for me, always top notch. Just no experience with RB25DET's.
so now we have Boosta and Uras saying 2 very different things :banana:
Any more opinions ? I'm leaning towards the cp ones, by te way....
WJ........
CP Pistons speak for themselves...... go have a chat to engine builders who use them in many different applications!
The way i look at it is, the proof is in the evidence of the product and the people who use them, I have seen Cp's in engines from the V8 Supercar Engines to V8 Twin Turbo'd Dune Buggies to 2 x Lamborghini V12 engines.
They all use the CP Pistons and the Ringsets provided by CP to suit the pistons.... Having said that Cp Pistons arent responsible for people who sell pistons with the wrong ring sets in them.
Wiseco are great for lots of different options but if you really are chasing pistons that are above the normal.... CP's are a great choice,
Cheers BOOSTA (pete)
WJ........
I tend agree with the wiseco comment, we used a lot of wiseco pistons in race bikes (with no dramas) but i have heard from plenty of skyline guys (not from personal experience mind you) that the wisecos are not the greatest.
comparing V8 supercars and top fuelers to your average rb is hardly a good comparison.
Overall the most important factor with pistons is the machinst and the installer.... both of with determnine the sucess or failure of a build. I can recount 100's of stories of late of customers who have engines built that are so loose they trip the knock sensors..... these were built by so-called reputable shops.... the same guys who build top end v8 engines...
I haven't heard of any CP's failing for reasons of bad manufacturing but I haven't heard of any Wisecos doing that either. Have you Pete? (Not attacking, just asking.)
I used Wisecos because they have a longer skirt so I think they stay more square in the bore which should long term result in less bore wear. Also the skirts are teflon coated from factory so less friction.
I think they recommend something like 5-6 thou piston to bore clearance (can't remember for sure though tbh). I used 2.5 and have had no issues.
yeah same deal with ARIAS, i use alot of ARIAS (great cheap piston) in jap engines and unless you tighten them up they rattle like all hell and you get excessive ventilation.
URAS... and ABO,
Your both correct, the wiseco's are a decent piston and readily available in many different shops.... In the end if the engine builder doesnt know how to install pistons correctly (hell CP even have instructions to follow for there pistons and rings)
As for the difference between the V8 supercar pistons etc, they are all made by the same machinists at CP Pistons and with the same material as ur standard off the shelf Forged Rb20, Rb25, Rb26, Rb30, Rb30/25/26head, etc etc <--- CP Stock
The only difference in the standard forged pistons to the customs is things like X Forgings, lateral gas ports, vertical gas ports, anti detonation grooves etc etc ( plus the basic things like to suit certain applications etc and heads, pin heights, flat top, dome, or dish, blah blah.... skirt length can be changed in custom aswell.
I have seen and spoke to many different workshops within Australia and we are still waiting to see a Real CP PISTON Failure...... or even a Ringset Failure that hasnt been caused by incorrect tunning (detonation)
Some of the shit I have heard scares even me sometimes with regards to what people do to engines,
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
