For Sale:
GA70, 1G-GTE powered. Constituting the stock 2.0L, running a set of stock Turbos. With EVERYTHING stock, except for the exhaust.
As a modification, it runs a 3" High flow exhaust.
This is the only modification.
The car currently has no stereo in it, but I will be fitting a Sound4 Radio, with standard speakers.
The car runs the electronic 4 speed auto.
Both motor, gearbox and diff are in good condidition.
I will be servicing the car very soon, so it will be done before the buyer gets it.
Tyres are in fairly good condition, on stock rims.
Contact details: Phone or SMS on 0406 962 347 or PM me.
Reason for sale: I want another R33.
Price: Asking $7000 ONO (Negotiable on price)
Pics will be up soon.
Thanks
Matt
https://www.sau.com.au/forums/topic/172648-mk3-supra/
Hey guys,
Really want to try and get this car gone by this Thursday. (Then I can get back enough money on my insurance)
Has rego until 4/1/08
Just ring/SMS me (I won't be able to take a call/respond until after 1PM on Saturday *16/6/07*)
https://www.sau.com.au/forums/topic/172648-mk3-supra/#findComment-3181093
Hey guys,
Hey bro - do you have a specific R33 already sourced?  I'm looking to sell mine (pretty unique).
This is my 1st post here ever, so bear with me :yes:
https://www.sau.com.au/forums/topic/172648-mk3-supra/#findComment-3203501
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
