Sorry Neil I don't understand what you mean.. are you asking what type of r32? R32 GTST rb20det 2 door coupe '92
yeah sorry bout that, it is what i meant. it the inner glass weather strip
, sits at top of the door fab.
Could I just remind people that need numbers that it would advantageous to supply the following: (after all u are getting this for free at the expense of someones time)
FOR REQUESTS: Please specify the following, the more the better and easier for me to get the right number for you.
Model: R32 R33 R34 S15 etc
Year: MOST IMPORTANT!
Colour: Colour if body part.
Model Number: Blue plate - Really handy if you get this
Chassis Number: Blue plate - Really handy if you get this
Edited by arbess
Hey, thanks for doing this guys.
Could you help me out with a part number(s) for the rear quarter window rubber seals for a 1993 R32 gtst? So im after the rubbers that go around the rear quarter windows.
VIN 6U9000HCR32292253
Model KRCR32RGFS3 FA
Chassis HCR32-292253
Thanks,
Shaun.
can you guys help.
Need the part number for the Rear Fog Light for the GTR 34.
Its on the rear bumper, Left side (white) is the reverse light..looking for the right side (Red) fog light.
Thanks heaps
Thanks,
Shaun.
bad news for u the rubbers are apart of the glass, so you can't get them as a seperate part. and in advance the part No. for the qtr glasses are as follows
83306-04U00 RH qtr glass
83307-04U00 LH qtr glass
ahh yes its true. not cheap either....
Dammit!!
Thanks anyway.
Shaun.
not sure if it has been mentioned yet but the part number for a genuine turbo to dump pipe gasket on an r32 gtr (should be same for newer gtr's but unable to confirm atm) is 14445-05U00.
hope that helps somebody out :-)
CONFIRMED!!!!
AND I HAVE FAST AGAIN!
From all the PM recently about me getting numbers, i thought it was a good idea to reinstall after i lost my copy.
and remember!!!!! in big bold fk off letters:
FOR REQUESTS: Please specify the following, the more the better and easier for to get the right number for you.
lawl.
  • 3 weeks later...
I dont think they are the same as RB26. Here is what I have for you,
RB25DET 93- 96
- Belt Fan & Alternator AY140-40850-
- Belt Compressor AY140-40910-
- Belt Power Steering and Oil Pump AY140-30845-
also
- Belt Timing 13028-20P25-
- Filter Oil AY100-NS007-
Good Luck,
Added
HI, just got these belts from Nissan Australia and the part numbers are different to the ones above
Fan & Alternator 11720-42L02AU
Compressor 11720-77A01
Power Steering 11950-58S02
I'm just guessing they are the Australian part numbers but not 100% sure.
Can you confirm if they are still correct for the following car
R33 GTSt 95 model
TYPE CHASSIS NO: ECR33-051545
MODEL NO: GGKBRTFR33VDA--JD-
Also is the Thermostat Assy the correct part number as well 21200-42L06
Thanks
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
