As said above .. $4000+ a set .. and thats used lol
I was concidering them but my r34 is a GTT and the dish would be crap in comparison to the GTR wheels .. LMGT4 great wheel tho
Check out Bee R - B5 if you like those .. :( Or koya drift tek
LOL, if you pay $4000+ for a second hand set, you are getting rip!
brand new set on 19inch ver05 can be had for 3k-4k
Yo peeps was browsin the net and checkin out r34's... and i came across these rims and had spasmic urges. What are they? Are they Nismo's ??????
THEY COULD BE RAYS WHEELS FROM JAPAN NOT COMPLETELY SURE BUT THEY LOOK LIKE RAYS
Do you think its better to order the seagull from Nengun or Greenline? I heard nenguns communication and waiting for the seagull to arrive can be a bit of a wait but gets there?
do you think a seagull would handle better with a drift wing or gtr wing?
yes sir i have a question, how did you get your car to that dirty location but not get dust on it??? i call shenanigans
that's a damn nice photo... can't wait to get some nice pics of my car...
Look similar to my wheels :) too bad mine have the studs around the outside :) Suit the subtlety of my car though - wouldn't want 10" dishy wheels (go before show!)
Nice shot. A little unbalanced picture "bottom heavy". Now just stick a seagull on the top half it will be complete :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
