Okay can someone clear this one up for me?
I see a lot of people on here have eaten up these clutches in a few months, whereas many have had them in for years with no issues.
Which of these is the best method for taking off?
Either:
- Slip the clutch slightly at low rpm (idle... 800rpmish) until you can safely drop the clutch without stalling or
- Rev it up a bit, and sorta slow-dump the clutch so it grabs with maybe a little chirp and takes off.
Or some other method I havn't tried yet lol.
Edited by Equinox
ive got one with the lightened flywheel and strangely i can just drop it in at idle with no revs. only works on flat roads of course. i find that if i give it a bit of revs its not as smooth. seems to work better for me with low revs and quick engaging(not dumping). the clutch just bites(you can feel it) and your ready to go. this is just normal driving. i havent launched it yet, never needed to..ha
p.s dunno if the flywheel make it this way though.
Rev it to the redline then drop it !!!! It will last you forever.....
Seriously with any clutch, any car if you want it to last gently does it , take off with as few revs as needed and let it out gently. If you are to do that you don't need aftermarket clutch the stocker will do just fine .
Either:
Any puck clutch - don't slip it at all - there's not a whole lot of friction material and riding it will eat it.
Before I put my twin-plate in I had a 6 puck single plate - dial up 1500rpm and drop it (tiny chirp).
Lasted for 30k kms on my old daily-driven GTR.
Regards,
Saliya
ive had one on my car for the last 12 months and it still bites like the day it was put in.
i hardly ride it at all. taking off i get to just where the friction point starts then add a few more revs
then let it all the way out. Not dumping the clutch but not riding it either. just let it out in a quickish, smooth action.
works for me!
I've got a heavy duty button.
I just give it a few revs and slowly let it out
if i release it too fast it just leaps foward =(
Launching it is so awesome though..
and ahh give it a nice kick in 3rd is also great! :blink:
I've had a cushioned button in mine for a year and half now (done 25,000K on it), and i'd never go back to anything else.
What I do is tap the accelerator so it revs it to about 1,500 rpm, take foot off accelerator so it falls, take foot off clutch completely in one motion as te rpm falls from 1,500, accelerate at exactly the same time as you take your foot of the clutch pedal altogether, and it takes off as smoothly as if you were driving a car with a normal clutch. You can control the launch by how quick you are off the clutch and on the accelerator, but if you really want to launch it, nothing beats a 3,000 dump. I can imagine your clutch won't last to long if you do that often though.
The trick is make sure you never ride it. If it's always on or off and never in between, it will last you a long time.
Practice makes perfect, you should be able to feel very easily whether your doing the right thing or not.
Edited by JDSracing
i glazed up 2 excedy brass button clutches, both in my old 33 gtst. had one in my gtr before the motor blew, so they all were a bitch to drive. i.e ur not suppose to ride them as they'll glaze over, i only learned on the 3rd time :domokun:
and once they start to slip, theyre gooone within a very short period
jim's clutch packs arent a true brass button material, theyre carbotic, a mixture of differnt types
Ive got a cushion button on my car, hated it for a month but now I love it...
I find that I can rev it just above idle then let it out quickly while putting on more throttle and its a smooth take off
I did ride it a fair bit while learning how to use it prolly wont last as long as some of these guys
I had not driven a manual for 2 years, went straight to a GTR with a button clutch and used this method and the clutch lasted more then a year (then i sold the car) and i did not feel any change, it was still gripping 100%.
ive had a cushion button (exedy) in now for a couple of months
cant say i ride it hard, but i certainly dont pop the clutch out to get moving
low revs, little slip, and away, its just like a normal clutch
dont do any high rpm launches
anyone would think these clutches needed voodoo to last.. I had a 5 puck in the R31 and it went strong for 3 years. I even blew my tailshaft on one of the rare occasions I forgot my mechanical sympathy. Daily duties are no problem - I never rode the clutch but I certainly slipped it a bit. If I did ride the clutch rather than just put my foot on the brake it would start to make angry groaning noises at me after 10 seconds or so, so I knew not to do that!
Bottom line, if you are a butcher then puck clutches have less friction material so they wear out quicker. Get a full face clutch.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
