  • Replies 85
Well as the cruise draws nearer it seems my car gets further and further away...
The way its looking i will not be on the cruise without some sort of miracle :)
pull your finger out Ben :) you can't Organise this and not come. :O
why's that GMB, what is there you need to do?
This weather is the main killer at the moment as i dont have a shed/garage the car is just in the drive which means on days like today i cant get anything done :)
Basically to get the car running:
starter motor bolted back on
couple of heater hoses attatched
FMIC piping bolted up with a few adjustments
run all new vacuum lines (and figure out the mess from the old EBC) along with the electrics for the EBC
redo fuel lines (have to disconnect the additional 2 lines) and also the 2 extra injectors.
put ignition barrel back in and fix wiring where it was damaged
have new 1/4 glass put in
put rotors back on (getting machined today) along with freshly painted calipers and bleed brakes
sort out rest of the engine bay wiring which looks like a scattered birds nest...
and then there are a few other little things that needs to be done before i can pit pass it :)
pull your finger out Ben :) you can't Organise this and not come. :)
Its not a matter of not wanting to do it, its more that i cant work on the car when its raining which has been 95% of the time i've had free :O
it's a bugga, you could use my garage if it wasn't full of shit for the new house.
Well i hope that most of the moving is done by then and nick has made my car runn better so i can come too.
The car is pretty much immobile anyway so would be a right pain in the arse to store it somewhere else :D
I will just have to grab a lift with someone if my car isn't ready, which is a pity as i was looking forward to a drive :)
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
