  • Replies 78
Not anymore, i popped that cherry tonight.
Had a great time out there. Early on there was virtually no one there. I managed to get 5 runs in and still leave early. The rest of the guys are still there putting in decent times.
Brads time were dropping quicker then a 15year old at a Timberlake concert. I look forward to the videos of him chopping me.
My best time was 12.39, 60ft of 1.88 and terminal of 171km/h.
andrew
Well done :(
12.39@106mph is an excellent time for the MPH. What was your half track speed?
Any other times? blk180?
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3189946
Thats a good time for your first time out padey, if you don't mind what have you got done?.
Yeah it gets like that when you arn't racing.
Not much done to it compared to other guys. 254kw on CRD dyno, turbos 16psi, PFC, cam gears, standard fuel pump + injectors + AFM's.
660' time 7.994
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3189999
[email protected] on 16psi. tyres Fedral 595SS Car hates going into 3rd had to fight it.
60th 1.849
660th7.660
Pop intercooler piping off next run and burnt my hands getting it back on after that 12.1 was best.
O yer i had 10 runs car probly needs more of a break between runs.
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3190080
andrew
nice time dude!!!! now you have it in your blood! you'll become an addict :action-smiley-069:
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3190777
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
