  • Replies 78
Not anymore, i popped that cherry tonight.
Had a great time out there. Early on there was virtually no one there. I managed to get 5 runs in and still leave early. The rest of the guys are still there putting in decent times.
Brads time were dropping quicker then a 15year old at a Timberlake concert. I look forward to the videos of him chopping me.
My best time was 12.39, 60ft of 1.88 and terminal of 171km/h.
andrew
Well done :(
12.39@106mph is an excellent time for the MPH. What was your half track speed?
Any other times? blk180?
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3189946
Thats a good time for your first time out padey, if you don't mind what have you got done?.
Yeah it gets like that when you arn't racing.
Not much done to it compared to other guys. 254kw on CRD dyno, turbos 16psi, PFC, cam gears, standard fuel pump + injectors + AFM's.
660' time 7.994
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3189999
[email protected] on 16psi. tyres Fedral 595SS Car hates going into 3rd had to fight it.
60th 1.849
660th7.660
Pop intercooler piping off next run and burnt my hands getting it back on after that 12.1 was best.
O yer i had 10 runs car probly needs more of a break between runs.
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3190080
andrew
nice time dude!!!! now you have it in your blood! you'll become an addict :action-smiley-069:
https://www.sau.com.au/forums/topic/173135-wsid/page/4/#findComment-3190777
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
