For Sale: Stagea Series 2 Double Din TV headunit
Perfect condition.
Asking Price: $165 plus postage.
Contact: Via pm or 0405 233 453
Regards,
Jordon
Edited by zaffa
  • 3 weeks later...
I am interested in this unit -as I want to get rid of my double din head unit that is in there
can you give me any more info as to what this unit does exactly
is it suitable for Australian use? Ie does not have japanese characters on the screen etc.
can you let me know via PM or just reply in this post
many thanks
Sean
hahaha, alright well for this unit to work in your car you firstly need the bracket that holds the unit into the dash (as this screen is slightly wider then a double din unit) which is simple enough, you also need the single din cassette player below is (as they work together for thing’s such as volume, cd stacker etc) probably also need to buy the CD stacker with it (if you don’t already have one) also in the boot in the drivers-left hand panel there is a whole lot of gear for the GPS, TV etc (i think) that needs to go with it, as well as all the wiring.
the screen unit is used for touch screen climate control, GPS (which only works in Japan, but you can buy GPS dongles that plug in and will work the same way), TV (which once again only works in Japan as they are NTSC and we are PAL. but in saying that chook bought a NTCL/PAL converter and got the TV working in his stag ;) check out this topic for a good read and more info http://www.skylinesaustralia.com/forums/in...showtopic=91085 ) and also this screen unit has a on-board CD player with touch screen control, so the screen folds forward, you insert the CD, push the screen back up and there is a full touch screen interface to control audio (but the volume is still used on the cassette player)
you will also need the cover that goes around the screen and cassette player as its different to the triple din cover. also its a direct plug over from the single din climate control to the screen unit, so no wiring issues there.
its a quality unit, the screen its self is fantastic, very fun to use and looks fantastic :domokun:
  • 1 month later...
  • 1 month later...
I don't like the car has the single climate unit/double DIN CD setup.But if the price is low,i will like.haha
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
