hi guys i have a r33 gts-t this is my problem, When i em in high rev's any wher between 5 to 7,000 my car starts to jerk and lose power. i know it could be hundreds of things but i want to know what you guys think it could be and if this has happend to any one else. THANKS IF YOU CAN HELP AND GIVE ME SOME FEED BACK
https://www.sau.com.au/forums/topic/173317-whats-going-on-with-my-r33/
Could be faulty AFM. Swap over if u have access, if not then resolderthe electrical contacts. Also check your coil packs.
Also if you have a pod filter, unsecured, get a CAI box or replace it withyour stock air box as this is what caused your problem with AFM.
99% chance it will be your ignition coils shorting out wich is a VERY common problem on the RB25DET engines
Quick test, take cover off the coils (black cover on cylinder head).. one way You could check them is to start engine and try to look for sparks whils reving and in the dark, But for mine the best way to diagnose if they are faulty (shorting out) is to give them a good spray with Inox (can be brought from bigw/ boating store etc) make sure you coat them well!.. than take the car for a good hard run and ill just about bet that you will no longer have the missing above 4500rpm, however this is not a permament fix.. it might last a few weeks max
The inox is insulating the parts of the coil that were beforehand leaking electricial current (shorting out) causing your engine to miss at the higher boost setting wich comes in at about 4500rpm from memory
If the coils are your probem there are ten thousand pages on here about how you can fix them or you can buy splitfire aftermarket ones wich is what some people do but your looking up to $1000.. i thing Sliding performance has a good deal on them atm for about $5/600
Dave
Edited by r33freely
You can check your coilpacks very easily. Remove the plastic cover over them. Then go for a 'spirited' drive at night when it's dark. Try to recreate the situation where the engine does its bad thing. Then pull over and pop the hood and stick your head in over the packs. I had bad packs, and when I did this, I could clearly see the spark arcing on 3 or 4 out of 6. Bought new packs, and 100% fixed.
Just easy to check this first since it's such a common thing in 'lines.
Just to let us know my car is stock all it has is a front mount and a pod filter
I had the same prob last week, it mostly occured when dropping down in gears on the freeway. it was my coil packs i took em out painted them with nail polish , it fixd them for now, i dare say coil packs are most prob next on my shopping list...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
