FOR SALE
1989 Nissan Skyline GTR
105000km
11 Months Rego
Body / Interior:
Body and Paint - Immaculate Condition
Retrimed Interior with Recaro Front Seats
R33 GTR wheels - A1 condition NO GUTTER MARKS with Good Rubber
Blitz Boost Gauge
Aftermarket Steering Wheel
Nismo 320km/h Speedo
Kenwood 6.5" Screen with DVD player
Kenwood Speakers and Splits
Alarm
Engine:
Apexi Power FC with Hand Controller
Upgraded Injectors
Upgraded Fuel Pump
R34 N1 Turbos - Ball Bearing
Nismo Dump and Front pipes
3.5" Exhaust
SARD Air Intakes
Aluminium Radiator
Bigger Front Mount Intercooler
GReddy Profec B Boost Controller
GReddy Turbo Timer
Driveline:
OS Giken Gearset Gearbox Upgrade
Suspesion:
Fully Adjustable Suspension All Round
- Shocks
- Camber
Car has made 298KW @ ALL 4 WHEELS
Price:
$28,000
Plates not included
Contact Details / Location:
Contact Steve
0433 351 006
Located In Sydney
EDIT:
Car also has
* Exedy Hyper Single Ceramic Clutch
* Apexi Exhaust Silencer Valve - Vert neighbour friendly
Picures:
Edited by belo
https://www.sau.com.au/forums/topic/173909-fs-1989-nissan-skyline-gtr-r32/
what's the history of the engine? if you know.
just noticed in one of the pics the bonet dampener has what looks like heavy oil stains all over it and a bit of dirt too. or did you just wash the car and it's wet? hard to tell in the pic!
more info the better, cheers.
  • 3 weeks later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
