Here goes for the second time..........................just spent an hour and lost the first post while upoading photos
Time to sell as i never drive it anymore, 170000kms on the clock and ive done 7 of those over the last 3 years that ive owned the car. I really dont like the idea of selling her but could really use the money elsewhere.
Ill try an describe it the best i can but ive done so much to it im sure ill miss some things,
Pearl paint with airbrushed bonnet, tinted windows
Lowered front and back with new KYB shocks, whiteline swaybar up front and nolothane bushes
Gtst diff with 4.3xx ratio
Hicas lock bar with all hicas lines removed
RB20det gearbox with exedy heavy duty clutch, new master and slave cylinder, braided clutch line
Walbro pump (255ltr/hr), gtr injectors (440cc)
Garrett GT3071R turbo on a monsta performance stainless highmount manifold and external 35mm wastegate with 1 bar spring
Braided water and oil lines to suit
3" turbo back exhaust
Exhaust wrap on manifold and dump pipe and garrett turbo bag on exhaust housing
Reco radiator with 14" davies craig fan for ac
K&N filter mounted under gaurd with 4" stainless pipework
Hybrid 600*300*76 intercooler with stainless pipework
Splitfire coils, turbosmart dual port bov plummed back, catch can
Wolf 3d v4 ecu running ebc with handcontroller mounted on dash
Dvd-cd-mp3 player with fold out 7" screen, new speakers front and rear, 2 amps, 12" sub in custom box that fits under parcel tray
Retrimmed interior light tan/cream swede
Gizmo shift light with pre shift, autometer boost gauge
This car has all been engineered with a RB20det in it, since then i swapped the RB20 for a R32 RB25. The engineer can update the report, the car came from factory with a RB25 so said it wont be a problem. Before putting the RB25 in i installed a gates racing timing belt and a pair of RB20det cams.
This head will bolt straight to a RB30 bottom end which i also have that will be included with the sale if wanted.
Im asking $14000 for the car and it has rego till december, if you have any questions please just ask
Photos will be up 5 mins, just want to save this first.
Edited by grim32
https://www.sau.com.au/forums/topic/173984-1991-rb25-r32-4-door/
Yeah thats the dyno with the RB25 although the RB20 made the same power with a bit more boost.
The RB25 seems fine, no noises or smoke. Im quite happy for you to do a comp test on it.
I only picked up the 3 litre bottom end cause it was cheap then had plans to later build a RB30DET for it but just lost interest.
Will also consider swap for a N15 pulsar plus cash if anyone is interested.
ร—
ร—
