  • Replies 51
Posted Images
not finished :thanks:
but 95% done
just waiting on an order for the filter.
going to weld on a 3rd -10 fitting that is going to double as either a filter mount OR for a speedflow fitting for plumbback
this is with 20 mins polishing
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
