I got canaried and the cop said i would get a epa notice or something, i have a 3inch exhausts from the turbo all the way thru, FMIC, Air Filter Apexi 1... and the letter EPA sent me was that... along with more but yeah.
"It is recommended that you restore your vehicle's emission control equipment back to the manufacturer's design to prevent further action."
So i don't get it... are they going to check my vehicle or just it is my first warning so if i get dicked next time they will check it ??
https://www.sau.com.au/forums/topic/174259-epa-notice/
u may or may not have a EPA summons coming to u, u never know with them. Yes they keep on record if u have been submitted to them before and if u get caught again with them non EPA compliant mods theres a strong chance u will be fined
https://www.sau.com.au/forums/topic/174259-epa-notice/#findComment-3198262
Adzmax; Nah the officer didnt take a picture of it, he didnt even put my air filter down on my defective notice just my wing and my ride height.
R31nismoid; yeah i already took off the air filter and it doesnt say that i have to get it checked just that i have to restore it back to stock ? so im thinking just the stock air filter or my whole exhaust system too ?
https://www.sau.com.au/forums/topic/174259-epa-notice/#findComment-3198415
unless you have received a letter from the epa confirming an appointment to have it inspected ,you have nothing to worry about !!!!!!
https://www.sau.com.au/forums/topic/174259-epa-notice/#findComment-3198663
It dosen't hurt to make sure you have all the stock bits and pieces handy if you do need to go to the EPA.
Word of advice, you are best off returning most of the bolt on modifications to stock to pass the EPA, including aftermarket ECU if you have one.
https://www.sau.com.au/forums/topic/174259-epa-notice/#findComment-3199150
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
